A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
212 Questions View all
How to open top lid on MayTag Bravo Washer 300 series
My MayTag Bravos washer, model MVWB300WQ0, has a coin inside. I need to know how to open the top lid to access the drum.
Score 4
Add a comment
1 Answer
Chosen Solution
fanniealambert, check this photo guide it shows how to remove it. Get the putty knife to depress the clips....Hope this helps, good luck.
Update (03/07/2022)
Just become aware of the fact that the link no longer works. Here are the written instructions on how to access the components, which includes removal of the Lid etc.
Component Access
Score 1
2 Comments:
this forum is closed
by
@Yoan Labelle Take a look at the attached document. It should have all the info needed.
by
Add a comment
Add your answer
fanniealambert will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 44
All Time: 20,844
