The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering.
283 Questions View all
Is there a way to replace a cord in the iPhone?
I accidentially dropped my iPhone and there was a puncture on the right side of the phone I then tried to unlock it to see if it was working but the cursor wasn't moving and later I realized the touch screen wasn't working so I opened the front panel and I saw a cord that had broke apart.How do I fix it?
Help plllease?
Comments:
Which cord is broken? What is it attached to? Can you take a picture of the broken cord and include it in your post?
by
My Cousin is trying to fix it for me but I won't see him till June. I am not complete sure but the upper right corner of the phone was pretty banged up and the cord was connect there.
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Well, the cord that would be most readily visible is the one connecting the interior buttons on the backplate... volume, silent switch, sleep, etc... these are also mounted on the top right of the phone looking from the back, so that could be what your referring to. If you can pull it in and out of sleep and adjust volume, this is not the problem.
The antenna cable runs along the right side (looking from the front) so this could also be what your referring to. To my knowledge, the longer one is for bluetooth and wi-fi (anyone, feel free to correct me if i'm wrong here) and the short one controls power to the antennas and your cell service. Severing this cable can be catastrophic, but may not be your problem considering that you seem to have visuals on screen.
Sadly, however, the chances of repairing any of the ribbon cables in these units is extremely low, if not impossible for the average bear. Same goes for the antenna cables as well. You most likely only need to order replacement parts to get back to normal.
Hope some of this information helps, or at least helps you diagnose what needs to be replaced.
Comments:
Thanks I'll check which cord it may be and try to reply i'll also send picture asap
by
Add a comment
Add your answer
Jailbreak Prince will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 744
