Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2521 Questions View all
My home, power, volume and mute buttons don't work?
None of my buttons work on my iphone5 i.e power button, home button, volume, and the silent switch. I can get on it only if some1 text/rings or I plug the charger in. I did notice at the top of the phone, the screen is pushing away from the sides, and the top looks like it's coming apart. Just wondering what part I need to replace it or if something has come loose and that's why it's pushing it apart.
Add a comment
Most Helpful Answer
This happened to my iPhone5s. I fixed it by holding down the power button and the home button at the same time. Hope this helps everyone else who has the same problem :)
Score 4
3 Comments:
btw hold the buttons for a while until a white screen with the apple symbol comes up
by
Yes!! This worked for me, thanks.
by
fixed it thank you!! :D
by
Add a comment
You need the power volume and silent flex but I would check that it hasent disconnect from the motherboard..
Doubt the screen problem has anything to do with the damage of the flex
2 Comments:
What about the home button?
by
You could try a restore and see if that sorts it..
by
Add a comment
Home you will need the home button flex or if it's not that it will be a charging port cause it has the prongs that make the home function ..
When did these parts stop working after a repair?
If so you may have damaged a part of the motherboard which function power and home button.
1 Comment:
No, all the buttons just stopped working at the same time for no reason.
by
Add a comment
Add your answer
Jade will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 8,262
