GSM version of the fourth generation of iPad released November 2, 2012. Model Number A1459 / 16, 32, or 64 GB
45 Questions View all
Ran out of battery, never turned back on.
Hi everyone.
Got a 7 months old iPad 4, and its dead as a dodo, battery ran out while using it, connected it to the charger the next day, and it never came back on, no apple logo, no charging symbol, does not respond to any reset procedure, two chargers (12 and 10 watt) was tried, and 3 cables, also tried connecting it to different computers, both mac and pc, no reaction.
And yes, its still under apples 1 year warranty, but since it was sold in Latin America, and i'm in Europe they don't want anything to do with it.
Its been left on the charger for 3 days, and no change.
Did the battery simply just pack up and died totally, or should i expect a logic board failure since the screen just stays black.
iPad was never dropped, never exposed to water, and is in pristine condition, except being a paper weight. :D
Any suggestions ?
Score 2
Comments:
Just to finish this up, new battery fitted, iPad is still dead.
So its the Logic Board.
by
Thanks for the update on this. I also have an iPad 4 and it is starting to exhibit signs of power issues. I wonder if this is a batch issue.
by
Add a comment
Most Helpful Answer
Plug the power in, hold the power button and the home button for about 10 seconds to reset the CPU. Maybe it simply froze.
Also sometimes the device refuse to take charge when it is too cold, warm up the device and try again
Score 2
Comments:
All that has been tried, also as noted in my original post, no response, just black screen.
by
Well apple was no help at all, so i voided the warranty myself, very disappointing considering its only 7 months old.
Battery is totally dead, 30 mW is all i can measure.
by
Add a comment
I would get a new battery and try that. If not get a new logic board and try that. Otherwise you may be out of luck.
Add a comment
if it was only 7 months old i would have been takin it to apple first no point buying parts when you can get it done for free
Add a comment
Good answer, except i tried that, Apple would not touch it, since it was from Latin America.
Add a comment
Tom C is the MAN works right away on my wife ipad2 ,issue was batt run out no picture on screen when charging no reaction at all, after 8 hrs on changer still nothing attach it to tv
its work but no data on touch screen with my high tech kaki confident skills I scream its the screen !you broke it you use to much but no worries high tech Jimmy is here!! I was browsing around looking for cheapest touch screen till i run to you guys,like I said Tom is D Man,hey Tom you are my new friend! but forgive me Tom since you do not exist on my wife world I fix it, thanks to you I'm her hero and will get lucky! and thanks to all I be coming around and share knowledge keep in mind knowledge is power.
JJAMVILL TELECOM
Add a comment
I have a similar problem,
the Battery went dead while i was making a restore.
now that i changed the battery the IPad is not starting up. Does that mean i damagde the BIOS on the IPAD??
And if so where is the BIOS located and can the bios be changed?
thx for any answer
Oli
Add a comment
Add your answer
Ronni N will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 28
All Time: 3,569
