Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2912 Questions View all
Searching network, old sim, normal?
My iPhone 4s had a bad dock connector. I originally intended to fix it, but ended up just buying the iPhone 5s because it was released at the same time and I didn't have time to fix it. Today I replaced the dock connector following Ifixit's guide. The phone charges and works fine, but the bar indicator indicates that it is searching for a network. GPS and Wifi work. I do not have access to a micro SIM with service. The SIM is in the phone, however is disconnected. Is it normal for the phone to perpetually be in searching status if my SIM has been disconnected?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
If you have a sim in the phone that is not active then it will stop searching and say not service, Check to make sure your iPhone has the correct date and time.
Score 1
Comments:
The phone has the correct date and time. Looks like I need to look into this further.
by
I went in and set the time to be wrong, then turned automatic time setting on. Looks like that worked, it now shows no signal. Thanks! Now I just need to find a micro SIM I can use to test the phone with.
by
Add a comment
Add your answer
Justin Strong will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 78
