The MacBook family was first introduced in May 2006 and replaced the iBook as Apple's consumer laptop.
3892 Questions View all
Why is the battery not charging?
I have a 2.0 ghz Core 2 Duo (Merom) White Macbook. It refuses to charge the battery now. When plugged in, the Magsafe adapter does not light up at all, but the battery icon changes to Not Charging. I have tried three different adapters with the same results. I have also tried two different known-good batteries (1 Apple OEM and 1 aftermarket) without any improvement.
I can still use the computer with only the power cord. If I remove the battery, the computer continues to function.
If I remove the power cord but leave the battery in, the computer will continue to function. The battery refuses to charge.
Any suggestions? It was charging perfectly overnight and has just stopped charging.
Add a comment
Chosen Solution
Just wanted to give you an update: I swapped the Magsafe port and board and everything is working fine now. Cheap fix, so if you have this problem try swapping the Magsafe board first.
Add a comment
Most Helpful Answer
Download and run Coconut Battery to get a much better idea of the status of your battery, let us know your results:
http://www.coconut-flavour.com
Score 1
Comments:
The charge status of the battery is 60%.
The health of the battery is 91%.
It has 4 loadcycles.
by
Add a comment
Add your answer
Jack Byrnes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 112
