2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
957 Questions View all
one purple vertical solid line through my LCD Screen
I dont know what the problem is. Ive owned this laptop since Nov. 2008 with no issues until now. I reset my PRAM with no luck. Is my LCD screen gone bad?
Score 1
Comments:
Does this show up on an external display too?
by
If you can take a picture of it and upload it that could prove useful.
by
heres what it looks like
[image|46196]
by
The line is always at the same location, and i dont have the right cable to hook it up to a external monitor
by
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
Is the line moving or always at the same location ? Same line location when changing the display resolution ? If you don't get the line on an external monitor and the line don't change location then the LCD panel is going bad otherwise it would be a faulty (or not well seated) LVDS cable (video cable).
Score 2
Comments:
The line is always at the same location. how do i check the cable connection?
by
then in this case check the LVDS(video) and other display cables and see if it helps
by
Add a comment
If you really need a new display, fire up terminal and enter:
ioreg -lw0 | grep IODisplayEDID | sed "/[^<]*</s///" | xxd -p -r | strings -6
This gives you the exact display specs. In this model Apple used a bewildering range of LCDs which are not interchangeble.
Score 1
Add a comment
Looks like you need a new LCD then.
Add a comment
there are airbubbles in your lcd, it will get worse once they pop.
it happened to me. it sucks
Score -2
Add a comment
Add your answer
Noland will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 3,627
