Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Important Logic Board #'s when searching for replacement
I would like to find out which #'s are imperative to match when buying a replacement logic board.
I am aware so far of:
Part #_ _ _ - _ _ _ _
Model #_ _ _ - _ _ _ _ _
Product EEE code contained in serial #
Processor # ex. T7400 SL9SK = 2.16 mhz
I don't know where to find the logic board's serial # on the board so I'm having difficulty determining the EEE code.
I want to buy the correct replacement board, but even used parts on eBay are very expensive and I don't want to screw this up.
If anyone has any advice on the important #'s I need to match up when finding a replacement logic board on a 13" MacBook, I would be very appreciative.
Or if I could find out my options in terms of boards that would fit and be compatible with my other components
I am willing to downgrade in processor speed, but am concerned the Core Duo boards won't fit in a case that a Core 2 Duo came out of. Or would be incompatible with my temp sensor connections(3 wall) or airport card.
Thanks to anyone that can help
Score -1
Add a comment
1 Answer
Chosen Solution
Here's how to replace the board: MacBook Core 2 Duo Logic Board Replacement
Here are the logic boards that will work for you, click on the part for the Apple part numbers: http://www.ifixit.com/Mac-Parts/MacBook-...
These should be correct now.
3 Comments:
Thank you for the answer.
I'm afraid I made a mistake not including the model # for the 13" MacBook I'm trying to repair.
I am trying to find out what boards will work in a 13" MacBook A1181.
by
Could you remove the battery and give us the specific information about which Mac you have. The A1181 includes 7 different models. I changed the above to the correct logic boards.
by
2.16 Ghz Core 2 Duo
Model - A1181
Ser. # - W8733263Z5W
by
Add a comment
Add your answer
Jared will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,119
