Replace/upgrade a broken motherboard
Hi!
I have a 15 inch 2009 MacBook Pro, with a 2.53 ghz processor (it uses the integrated nvida 9400M only) with a broken motherboard (water spill).
On the internet I can only find de 2009 2.66 Ghz motherboard (that also has the nvidia 9600gt, as well as the 9400M).
Can I use this 2.66 ghz motherboard to replace the 2.53 one? Will it fit the case? Does the dual GPUs will give any problems?
Add a comment
Free Shipping on all orders $79.00 and up.
Browse Our Store
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
1 Answer
Chosen Solution
The logic boards are very different as the 2.55 GHz unit has a cutout for one fan and the 2.66/2.8/3.06 GHZ model has two (you will need to replace the fan units & heat sink if not supplied with the logic board). Yet the top case part numbers are the same Glossy 661-5244 & Anti-Glare 661-5297. So its physically possible fitting into the case.
Score 2
Add a comment
Add your answer
danf will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 199
