7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
177 Questions View all
Smart cover doesn't work
I replaced the touch screen of my ipad mini, everything works but not the magnet sensor to activate the smart cover.
Can someone kindly help me? thanks
Comments:
Hello, not to over simplify this but did you check the setting option to enable Smart Cover feature?
by
Did you ever get it to work? I just checked everything and all the parts are there.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Hi,
May be you have missing parts in your new touch screen.
The magnet sensor is on the right side of the home button, on the home button flex cable.
See your old one digitizer.
Regards.
Score 1
Comments:
Could you kindly send me a picture? Where is the sensor on the home button flex? Thanks
by
iPad Mini Wi-Fi Front Panel Assembly Replacement
Picture from step 28.
There is a black tape on the flex cable. You can see here on the cable one small element with 4 legs. And there is other elements under the tape.
And on the corner of the digitizer you can see small magnet. You must have another one on the next corner.
May be you have missing parts on this flex cable.
by
Add a comment
This problem is due to non-original home flexes that are missing a couple SMD components necessary for smart cover function. Return that digitizer assembly and order one from a supplier that is aware of the differences between original and non-original home flexes.
Add a comment
Is the a way to solve this problem? To appear tha Lock/Unlock option? Why when I reset my Ipad I can't Lock my Ipad using the power button?
Add a comment
Add your answer
Cyberia Informatica will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 23
All Time: 1,803
