Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3237 Questions View all
Should I try replacing the motherboard as a novice?
I was told here that because my wifi is greyed out and my camera flash is dimly lit since my phone got wet that my motherboard/ logic board might be corroded.
Being a relative novice in the iPhone repair world (I have replaced the battery and the wifi antenna) should I attempt this repair?
If I should proceed, where would be the best place to get an OEM motherboard/ logic board since they don't seem to sell them on IFIXIT?
Add a comment
1 Answer
Chosen Solution
Only you can decide wether or not you feel comfortable proceeding. With that being said, here are a couple of points to consider:
1. Have you viewed the appropriate guide, such as this one for Repairing Liquid Damage?
2. Do you have the appropriate tools and working space? If not, can you, or will you acquire what you need?
3. For iPhones, the logic board is essentially the phone, that's why iFixit doesn't sell them. Purchasing a reliable logic board by itself can easily cost you almost as much as a new device. However, trying to properly address the potential liquid damage would cost far less.
4. I have found that eBay tends to be the "best" source for logic boards, provided that you are willing to tread carefully. If you just buy the first one that you find, you may be out of luck. If you still want to get a new logic board, make sure that you only purchase from a reputable source, and be sure that you have read and fully understand the description, condition and implications of both before proceeding with a purchase.
Good luck to you!
If you found this helpful, please up-vote or Accept Answer.
Score 2
Comments:
Thanks Joshua! I looked over the liquid damage damage guide and I will give that a try. I appreciate your thorough answer. I will let you know how it goes!
by
Sounds good! Thanks!
by
Add a comment
Add your answer
David Smith will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 94
