Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3238 Questions View all
areas of my screen/touchscreen do not respond
So i been having my iphone 4 for about a year now my screen was cracked when i got it. I been having problems with the touchscreen not responding so i took it for a screen repair but my screen still didn't work even though the guy would say it would. do i have to repair the LCD for the touchscreen to work again
Score 1
Comments:
mine won't work on the whole touch screen!
by
@Aurora, what have you tried to fix it? Hard reset, soft reset? If that does not work, it is possible that your digitizer has failed. You will need to replace the display assembly.
by
Add a comment
1 Answer
Most Helpful Answer
Is the screen touch not responding in the same location??
It could be faulty but in rare cases it can be the motherboard causing the problem..
Had this problem b4 with the motherboard tryed 3 screens and no luck all screens worked 100% in my test phone
Score 1
Add a comment
Add your answer
Andre will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 83
