PlayStation accessory repair and support, mainly for controllers. Repair usually requires common screwdrivers and prying tools.
389 Questions View all
Will a different V and mAh replacement battery kill my PS3 headset?
I have torn down my official PS3 headset to change the battery. The original battery is a 3.7V 1350mAh battery. Replacement ones are 4.2V 1800mAh. Will that burn / grill / kill my headset?
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Ben Hamel, the mAh will not but I'd be a bit leery about the higher voltage. It may be okay for the controller to handle it, but you are looking at a 15% voltage increase. I'd try to match the recommended voltage a bit closer. You might get a bit of a better answer if you can tell us exactly which headset you own.
Comments:
The headset I own is this one : http://m.us.playstation.com/ps3/accessor...
The original battery was an LIP 1472 Li-Ion.
by
Add a comment
Add your answer
Ben Hamel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 535
