Formally called the Chevrolet C/K.
169 Questions View all
Brake lights won't shut off
Why wont my brake lights shut off?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
steven williams, sounds like a bad brake light switch. Use a multimeter and see if you have always continuity. It is also possible that it has dislodge and is always on. If you let us know exactly what vehicle you have, may be we can help you a bit better. Here is a general adjustment procedure for a Chevy P.U:
Switch Adjustment
1. Apply the brake pedal.
2. Pull the lever (A) back to its stop.
3. Pull the brake pedal against the pedal stop.
Hope this helps, good luck.
Score 1
Add a comment
Add your answer
steven williams will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 102
