Model M4753 / 233, 250, 266, 292, or 300 MHz G3 processor
19 Questions View all
Where is the display inverter on the Wallstreet?
I am attempting to replace the inverter on my Wallstreet. There isn't a guide for that procedure here, but I went through the display removal guide, expecting to find it under the clutch cover like the Pismo.
Well the joke was on me, as it wasn't there as I'd expected. I see that the inverter cable connector plugs directly into the logic board which leads me to believe that it is inside the display cover itself.
Am I missing something or does the inverter truly live inside the display cover?
Thank you so much!
Randy
Score 1
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
randy3833, the inverter is tape to the LCD with what appears to be Kapton tape. Here is a decent guide for the "Wallstreet" and page 16 shows the location. Hope this helps, good luck.
Comments:
oldturkeyo3! Thank you! I figured it was in there somewhere. Just hated to begin an unnecessary disassemble.
I will check out the guide. So appreciate it!
Randy
by
Randy, you are welcome. Thank you for accepting my answer, best of luck to you.
by
Add a comment
Add your answer
randy3833 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 69
