Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2946 Questions View all
No phone calls can be made, unless speaker is used.
Hi There,
Today I have replaced an display of the iphone 4S. When testing I discovered that (when placing a call) the other end can't hear me. Only weird beeping cracking sounds are heard. Putting the phone on the speaker, everything is fine. No recording can be made by the dictaphone.
I think that by assembling the phone again, the ribbon cable of the noise cancelation mic is damaged.
Which ribbon cable do I need to order, and (of course) is there a guide for this?
Thanks,
Jos
Appologies for my bad English.... :-)
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Hi,
When you make a call, the iPhone used down microphone (it's on the доцк connector flex cable):
iPhone 4S Dock Connector Replacement
Pic:21.
When you use loudspeaker function the phone used upper microphone (it's on the headphone jack flex cable):
iPhone 4S Headphone Jack Cable Replacement
If you have problem with down microphone, this is your part:
Otherwise you have problem with mainboard.
Regards.
iPhone 4S Dock Connector Image
Product
$19.99
Guide
Difficulty:
Moderate
25 minutes - 1 hour
iPhone 4S Headphone Jack Cable Image
Guide
Difficulty:
Difficult
2 hours
Score 3
Add a comment
Add your answer
jlaenen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 86
