Everything you need to repair your iPhone yourself! From the newest iPhone 15 lineup, all the way back to the original iPhone 2G released in 2007, iFixit has free repair guides and disassembly information for every single iPhone, as well as the best replacement parts, tools, and tips in the galaxy.
36450 Questions View all
Question Closed
set phone down in condensation...home button doesn't function now
Home button doesn't work at all now - everything else does. I set it down next to a glass of ice water on my granite counter and didn't see condensation! Home button worked for two days off and on, now it doesn't work at all. What should I do here? Thanks
Add a comment
1 Answer
Chosen Solution
well - the main steps are pretty easy to tell:
disassembling, cleaning, checking, reassembling ;-)
here are the guides to the 3 iPhone models.
open it as described and take a look at the home button - i would guess that there is some "white" stuff under it and that would make some problems - it would simply short some stuff inside the phone.
clean it carefully with rubbing alcohol and a soft paintbrush, let it dry (really dry) - after that, reassemble it and try if it works
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 835
