Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1497 Questions View all
not charging after water immersion.
wife's iPhone died after getting wet,dried out,would switch on but not charge,changed the battery using great fixit guide.(connector 3 is a hard one,better pic maybe?).will switch on ok but still won't charge,any ideas please ??
Comments:
thank you both for your time and taking the trouble to help a novice techhead.will try the cleaning first and if no good the dock connector
by
you're welcome ;-)
by
alas new dock connector,battery and a good clean up have failed to work.phone functions ok except for taking a charge.thanks for the sound advice though.
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Most Helpful Answer
had the same problem with my iPhone 3G.
replaced battery,dock connector...
checked charge/usb chip
(Linear Technology LTC4088-2 Battery charger/USB controller)
http://cds.linear.com/docs/Datasheet/408...
check vbus=5v
in my case I had to change the LTC4088 and another chip this position (backside/logic board)
http://forum.gsmhosting.com/vbb/f456/iPh...
if your ltc4088-2 chip is ok check the "position" shown the link above.
its not easy!!!but now its ok!
read this: (to see pictures you have to register (free))
http://forum.gsmhosting.com/vbb/f631/iPh...
http://forum.gsmhosting.com/vbb/f456/3g-...
http://www.yobbgsm.com/2010/04/iPhone-3g...
(usb-solution)
Score 2
Comments:
nice - but to be honest - most of those repairs/hacks/unlocks are nothing for the "standard user" - mostly half legal vendors in the background. i have 2 accounts there - my first one is from my old cell phone repair days in 2001 ;-)
by
Add a comment
fluid damages are always problematic - there are sometimes tiniy shorted parts on the logicboard and the dock connector.
those parts have to be cleaned carefully with a soft paintbrush and rubbing alcohol - let it dry (really dry) and if everything is clean - reassemble it and try it again
Add a comment
You may have to replace.....either the battery or the dock connector.
Add a comment
thanks but i've reached the limit of my tech ability.the good lady will have to look after her next phone !
Add a comment
hello my apple iPhone 3G dropped in water dried perfect but I have a problem everything worked, the touch screen does not work I tried to change it again but do not want to know. how can I fix this? thank you very much.
Comments:
please start a new question for that
by
Add a comment
Add your answer
gareth jones will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 16,903
