2.3L 4cyl or 3.0L V6, 6th Generation
298 Questions View all
My horn keeps going off intermitently how do I stop it?
My horn keeps going off intermittently. Some times it is a long honk and other times it is several short honks.
Why is it doing this?
Where is the fuse for the horn? Or where are the horn wires located so I can pull them out? I checked both fuse boxes on right and left side of dash and no 'horn' fuse is listed.
I do not have an alarm system or a manual.
The service light is on. I don't have $ right now to take it in.
I'm looking for a quick fix.
Thank you
Score 1
Comments:
What model and what year is your Honda?
by
It's a 1998 Honda Accord LX
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
KJ Marsh, Under-hood Fuse/Relay Box fuse number 47 is the Horn as well as for the ABS control unit, Brake lights, Cruise control unit,Horn relay, Ignition key light, Key interlock switch (A/T), PCM or ECM. So, no way you can pull the fuse. What you can do is to pull and replace your Horn Relay. the horns are located in front under the hood beneath a cover. Hope this helps, good luck.
Score 3
Comments:
Oldturkey03, I also have a 2000 Honda Accord 2.3L 4cyl with a similar but different problem. My horn randomly engages (not sure if grounding somewhere or humidity is cause). Yesterday my horn stayed on for 25min (I was out of town) and automatically shut off. However, now every time I engage the horn button on the steering column, the 20A STOP fuse blows. So as long as I don't use my horn (or it doesn't randomly engage) my fuse #47 will not blow.
A replaced horn relay does not fix the issue. Also, when I do press the horn button, the horn engages for about 0.1seconds before the fuse #47 blows and the horn no longer is engaged.
Would you have any leads or guess as to what is going on?
P.S. I just created an account so please excuse if I'm incorrectly posting/replying.
by
@parker_ could be caused by a short in the horn itself or by the wiring to the horn. Unpluig the horn and push the button. If it blows the fuse you know it's the wiring. If it does not, you will know it's the horn
by
@oldturkey03
If I have had the same problem even after replacing the horn relay what should I check next? Horn wiring or the horn itself perhaps?
by
my problem started when i started my car, the horn started honking for about 30 seconds then stopped for about 5 seconds then started again for another 30 seconds, i drove home with this going on as well as the hazrd indicators going off and on, once home i then took the battery lead of the positive pole, i've also taken the horn fuse out, this stopped the problem but id like to know more as to how to fix it and what could be causing this to go off all of a sudden
by
Add a comment
Thanks KJ, no more horn blowing! At least now I can troubleshoot it without eliciting the wrath of my neighbors, much appreciated!
Add a comment
The battery in your key fob is dying. Change or remove the fob battery - problem solved.
Comments:
Is the battery replacement a for sure fix? I had my horn previously go off twice, randomly, for about 30 seconds. It was only until I hit the horn itself a few times that it finally stopped. I have since replaced the battery and will see if it happens again. It has only been a day or two so I cannot for sure say yet. I sure hope that is all that needs to be done! Thanks much for the information.
by
@gberge88 Have you had any issues since? Also, which make and model?
by
I actually just unhooked the horn under the bumper. No more random horn noises, however no more horn ever haha. Keeps me from honking at eradic drivers all the time I guess.
by
Add a comment
Add your answer
KJ Marsh will be eternally grateful.
Past 24 Hours: 52
Past 7 Days: 417
Past 30 Days: 1,914
All Time: 22,840
