PB won't start-up after reassembly & resetting keyboard
I took it apart again, reseated the keyboard connection, checked the on-button connection, and reseated the trackpad connection. No change. Say, what's the problem with scotch tape. I replaced the torn up yellow tape with it. Gulp! Thanks
Comments:
Why did ou open it up in the first place? What did you do?
by
I was changing out the keyboard. Six keys stopped working after it got wet last summer. Also, the display data cable is going. It was crimped at the hinge and display was going in and out. Changing it is a BIG deal to me, as the keyboard proved. Looking at used Mac Pros. I bid contracts off plans on my laptop, so need the big screen. Thinking it's time to give in. Opinions? Thanks
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Connector
If the connector was not torn loose check the alignment of pins... Given a known good keyboard the connector is the point source failure... if the replacement was a used keyboard could be switch or wiring faults.
If you want a larger screen a new box is the only way to get one.
If this answer is acceptable please return and mark it.
Good Luck,
N.
Add a comment
Add your answer
Dick Grier will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,090
