Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2911 Questions View all
iPhone 4s touch/digitizer not working
The touch screen is not working on this iphone i bought to repair. I ahve tested 2 screens on a different deviec and they work fine. But when used on this particular 4s the screen will turn on, but will not recognize touch. I have tried restoring, no help. What could be causing the digitizer to not work?
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Take a look at the digitizer connector make sure it is clean and you don't see any damaged filters or resistors around the connector.
Comments:
It looks like maybe one pin on the digitizer connector may be missing when I compare it to the other 4s I have. Is there any way to fix this? I'd really like to get it working because it's factory unlocked
by
Add a comment
Nearly anything on an iPhone can be replaced--it is just a matter of how much time/resources you want to invest. It would take very specialized talent to desolder the connector socket and solder on a new one without breaking anything else on the board
Add a comment
Add your answer
Zach will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 474
