A smartphone by Samsung running Android, identifiable by the model number GT-S5570, released in 2011.
19 Questions View all
I forgot my Galaxy Mini password, how do I reset it
As I switch my phone on, It requires a (pattern) password and I have forgotten it
Score 21
Comments:
Did you set a pin number incase you forgot your pattern?
by
No I never set a pin number
by
wifi and bluetooth not working
by
Add a comment
Chosen Solution
Hi,
If you make some wrong entries the phone will offer you to log on with your google account. But you must have WiFi connection. You can't make new connection and your WiFi must be turned on from before.
The second way is with adb commands. But for this you must have enabled USB Debugging from before. Otherwise you can't connect it with the PC.
The third way is Factory Reset but you will LOST all your data. Push and hold together vol(+) and power on keys.
With vol(-) chose Factory Reset. The power on key is for ok.
Samsung Galaxy S5 - Password, Screen Lock Removal
Regards.
Score 5
Add a comment
1-code formati https://www.facebook.com/rebels.tn.3
2-conneceter sur wifi entre email et mot passe
Score 2
Add a comment
yes
Add a comment
I tried it ten time and it said type your Google account and it said it rong
Add a comment
omg it worked thank you and keep up the good work
Add a comment
Add your answer
King James will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 96
All Time: 13,589
