Camera app has virtual shutter closed after camera replacement?
So I was fixing two iPod touch cameras, and after putting in the new camera and connecting the flex cable they seem to have sat in fine. Upon reassembly I realised that the camera app would not work. It as as if the camera would not initialise. The virtual shutter is stuck closed, and the button for actually taking the picture is greyed out. I'm baffled as a google search was to no avail and I need this fixed in a few days. Thanks in advance everyone! :)
Add a comment
Free Shipping on all orders $79.00 and up.
Browse Our Store
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Chosen Solution
I'll do that, but one of them started magically working again. It may just be the ribbon cable falling out because the seating is bad. The one that worked still had the heatproof tape holding it down, the other doesn't. Electrical tape should probably work but I'm skeptical.
Score 1
Add a comment
Check the available memory of the iPod, if you have zero available storage then the camera will not work.
Add a comment
Reset all settings and try again.
the shutter closed is the camera app trying to operate but the logic board is not getting the signal to and from the camera as normal. Once this happens, ie, you removed the camera or the camera was damaged, then the app needs to be reset in order to try again--hence reset all settings. As I recall just a hard reset isn't enough to reset the app.
If this doesn't work, then it is likely that you may have damaged some tiny component that is part of the camera trace on the logicboard....this is very common on the iphone 4 as collateral damage done just by popping off the LCD connector. In this case, check the board carefully especially around the area of the camera connector to see if you can spot a missing capacitor/resistor. Let us know what you find!
Add a comment
Add your answer
fnqirepair will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 338
