The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
214 Questions View all
Can I install a hard drive with incompatible ports?
Recently bought a G5 A1177 at a thrift shop. It doesn't have a hard drive. Bought a used one that matched the parts number I researched. The ports on the hard drive do not match the plugs in the computer- is there any way to use this hard drive or do I need to buy the correct hard drive? How do I know which drive will have the correct port?
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
These older mac's have the older PATA HD's so you will need to find one with the PATA port Vs SATA port.
While there are PATA to SATA adapters still out there I'm not sure if it will work here. You have some space issues to get it to fit and you also have the way the OS is expecting to 'see' the HD which may not allow it to boot up.
This series uses a PowerPC CPU chip from IBM Vs Intel's which is what is used in todays systems. The OS versions are very limited as well as the apps, so the long term investment on this system is limited.
This is the system people often get to create a Hack'in'tosh system as many liked the case (and it was often cheap).
Score 1
Add a comment
Add your answer
Beth Kelley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 100
