Dim Green light on Charger after water spill
I'm working on a MacBook pro core 2 duo unibody model, It suffered some liquid damage, but their is no corrosion that I can see. I get a dim green light on the charger and I know its not the dc-in board, bc when I plugged that into a board with no liquid damage, I get a bright green light. With the damaged board, I only get power if I hold down the power button for around 30 seconds. But just high fan speed no video or chime, I'm not sure if the board is charging, but I know the fans a were running when I had the battery connection but not the magsafe, can I get some idea's as to what fuse controls the board getting proper power. Or what I need to do to get it functioning the way it should
1 Comment
I"m confused are you putting the damaged DC-in board in a good machine or just connecting the power supply to a good machine?
by originalmachead
