Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
565 Questions View all
Can I Disconnect the Optical Drive without Errors in my iMac?
I have an old iMac EMC2133 with an optical drive that is failing. I don't need the optical drive.
Following your guide, I can remove or disconnect the optical drive. If I simply remove it or disconnect it, will the computer work properly? Or do I need to replace the drive.
Currently, the optical drive runs constantly, repeating the eject cycle over and over.
Add a comment
1 Answer
Chosen Solution
Yes - you can do that, you can leave the bay empty with no ill effect.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Add your answer
jacbrown will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 60
