Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1409 Questions View all
Can't partition new 500GB drive?
Installed 500GB drive. MacBook recognizes drive but Disk Utility shows 3.6TB! When I try to partition the drive it fails with input/output error. Have rebooted several times from OS X install disc.
Comments:
Thanks Machead3, but it's a Toshiba SATA 2 (3GB/s).
by
Thats SATA II (3.0Gb/s) b=bits B=Bytes
by
Add a comment
Chosen Solution
Sorry dolmen ;-{
Your system can only handle SATA I (1.5 Gb/s) drives. See if this Toshiba drive offers a jumper to drop the I/O speed (check the spec sheet for it online).
Also, make sure your firmware is unto date, checkout this Apple TN on how to check it and update it EFI & SMC firmware updates for Intel-based Macs
Score 1
Add a comment
Most Helpful Answer
Double check that you have the right SATA type… a SATA I or II not a SATA iii (what many new drives are).
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Add your answer
dolmon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 68
