Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
555 Questions View all
What is the shipped memory configuration?
To increase my 2GB memory iMac EMC 2210 to 4Gb I will need 1, 2GB memory stick or 2, 2GB memory sticks?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Here's the EveryMac specs for your system: Apple iMac "Core 2 Duo" 2.4 20-Inch (Al) Specs
As you can see the system comes with 1GB of RAM (using one 1GB module). In your case your system has two 1GB modules for 2GB total RAM. Your system only has 2 memory slots.
Your choices are: To remove both modules and put in two 2GB modules to get to 4GB of RAM (which is what you asked). Or, you could also go up to 6GB by using one 2GB and one 4GB modules. Which is the systems limit
In any case I would recommend upgrading your EFI to the latest version for your system. Follow this Apple TN on how to do it: EFI & SMC firmware updates for Intel-based Macs.
Score 2
Add a comment
Add your answer
tompryts will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 89
