The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
312 Questions View all
Backlight doesn't work after LCD replacement.
I had a cracked LCD screen. Prior to disconnecting the LCD cables the backlight worked fine. I replaced the screen but since then the backlight doesn't work. I confirmed the backlight cable and LVDS cable are securely attached. What are the possible causes?
Comments:
Did u get this fixed ??
by
Add a comment
GIVE TOOLS. FIX FOREVER.
GIVE TOOLS.
FIX FOREVER.
Spread the Fixmas cheer.
Chosen Solution
Blown fuse/controller for the backlight. This is not a DIY repair unless you work with electronic component replacement on a regular basis. Logic board soldering requires special tools, solder & lots and lots of practice.
Follow the tag at right for more information.
If this answer is acceptable please remember to return and mark it.
Score 1
Comments:
Is there a way to confirm this visually before taking it in?
by
Kimberly, if you have a multimeter you could check the fuse for continuity.
by
Where is the fuse?? Location
by
Add a comment
Check your backlight cable ... I installed mine the way the cable was positioned and best I got was black screen with faint apple symbol .....
But turns out I had it in backwards ... Was very awkward to flip cable and install bit that was it , try that just for !@#$% and giggles
Score 1
Add a comment
Add your answer
Kimberly will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 354
