Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2956 Questions View all
Battery connector doesn't match phone's connector
I bought my daughter a used iPhone 4S. Battery won't hold charge. Bought replacement battery, but phone's connector for battery lacks holes for 2 Phillips screws, is a different shape, but connector "fits". Interestingly, the battery conn. was held down by clear 2 sided tape, since it lacked screws to hold it down. Is this a modified phone?. Phone won't restart. Get Apple on screen, turns off, then apple reappears. See photos. Notice there are no holes for the two Phillips screws on the phone.
Comments:
robwageneck not sure where you posted the photos. Use this guide Adding images to an existing answer to help you with that. Also, take a look at the back cover on your phone and see if you can give us the model number.
by
Thanks for your assistance oldturkey03. I uploaded 2 photos but they are stuck in he images folder. The model is A1349
by
robwageneck, just follow the guide and pull them into your question while you are at the edit screen
by
Add a comment
Chosen Solution
robwageneck, according to the number you supplied (A1349) your phone is actually a iPhone 4 A1349: iPhone 4 (CDMA model), not a 4s. You most likely have the iPhone 4s battery which will not fit the iPhone 4. Check the attached images:
iPhone 4 CDMA model
iPhone 4s
Hope this helps, good luck.
Score 1
Comments:
Thanks. The phone was sold to us as a 4s, it runs Siri, but must be a 4. Thanks for all your help.
by
Add a comment
You purchased a fake battery, Return it.
They are cheap on ebay here
http://www.ebay.com/itm/111182198739?ssP...
Add a comment
Add your answer
robwageneck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 182
