Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
432 Questions View all
Headphone jack / digital output disabling internal speakers
I have 2 macbook pro's, one late 2008 and a early 2011. Right now both are showing the same problem.
Internal speakers being disabled by the digital audio detection on the headphone jack being turned on by a faulty device.
My question is, after a lot of research, in which problem say to put foreign objects into the headphone jack to try to reset the sensor, is there a way to replace (yes I know its solder in)? Where can I buy the headphone jack only without buying the whole logic board? (which is where its solder in).
Comments:
I am not an expert but I am savvy as in electronics. But I can't find anywhere on the net where to buy a replacement if any. And yes it crossed my mind to simply buy a usb audio port for it.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Soldering logic board components is generally not a DIY project. MLB are easy to destroy. If you are a small electronics/computer repair technician with the special tools, solder and experience to accomplish this task you most likely would not be here seeking advice.
A work around would be to use a USB audio adapter which would contain a headphone jack (USB AUDIO works separate from analog and optical), or, a USB voice quality headset with builit in microphone.
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Add your answer
Hector Rosa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 680
