Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
435 Questions View all
Battery not powering Mac, New Battery, New Power Logic Cable.
Hi,
i have replaced the Battery, and Logic board battery cable, computer still only works with the AC, turns off IMMEDIATELY after AC is removed... is the next step a new logic board??? $600 question....
Add a comment
1 Answer
Chosen Solution
Help us help you. The more we know for certain the more help we can be.
The trigger that caused you to decide to replace the battery and logic board cable certainly can could be the reason why the machine suddenly shuts down after the AC power supply is disconnected.
If there was a liquid spill it would not be out of line to replace a damaged logic board, and a liquid spill could cause the problem you're having. So might a power surge.
Examine the logic board under a magnifier… look closely for burn marks, corrosion or swollen components. If you find some that would indicate a logic board replacement… DIY component replacement requires special tools, solder and lots & lots of practice… it's nothing like soldering a lamp cord.
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Add your answer
logan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 101
