Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3215 Questions View all
Why is my phone making noise but won't turn on?
I shattered my iPhone 4 screen and I disassembled and reassembled it myself. I fixed my screen but the phone will not turn on. However, it keeps making this weird beeping noise when I put it on the charger. What does that mean? I would've took it to a professional but they tried charging me $150 just to get a new screen.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Check your work very carefully. Make sure the LCD Display Flex cable is perfectly pressed down to the logic board connector. Make sure the Dock Flex cable is perfectly pressed down to the logic board connector. Make sure the battery connector is perfect.
Score 2
Add a comment
my phone does the same thing but is not broken my iPhone 4 freezes and I press home but nothing happens then I press the standby button and I press it again and there is no display but when I plug it on the charging cable it dings therefore I know it is still on so I disconnect the cable and leave my phone alone for a day and It goes dead then I press the standby button and it displays the "need to charge" icon on the screen then disappears I charge it and it works fine the next day,I hope this helps-jade
Score 2
Comments:
can u try to help me
by
Add a comment
NY iPhone 4 is diving the same my screen was cracked u changed it now the phone won't come on but when I plug it up its making a double zig zig sound then a thump I recheck all my cables and the battery some thing happens
Comments:
try to connect it to the Comp. with USB and see will it recognize....if yes than is your board still good just check all the flex cabels
by
I changed the screen out again this morning now it lights up and talks but no apple logo its just blue I did the home and power button it just turn off and back to blue screen it go
by
Add a comment
My iphone5c is blacked out but when I put it on the charger it ding what do I do
Comments:
just hold the power and home button for five seconds, like your going to hard reset it. As long as you only hold it for five slow seconds it will work and it won't reset your phone. (this works on all iphones)
by
Add a comment
Add your answer
richonna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 45
All Time: 5,527
