Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Why is my phone making noise but won't turn on?
I shattered my iPhone 4 screen and I disassembled and reassembled it myself. I fixed my screen but the phone will not turn on. However, it keeps making this weird beeping noise when I put it on the charger. What does that mean? I would've took it to a professional but they tried charging me $150 just to get a new screen.
Score 5
Add a comment
Chosen Solution
Check your work very carefully. Make sure the LCD Display Flex cable is perfectly pressed down to the logic board connector. Make sure the Dock Flex cable is perfectly pressed down to the logic board connector. Make sure the battery connector is perfect.
Score 2
Add a comment
Most Helpful Answer
my phone does the same thing but is not broken my iPhone 4 freezes and I press home but nothing happens then I press the standby button and I press it again and there is no display but when I plug it on the charging cable it dings therefore I know it is still on so I disconnect the cable and leave my phone alone for a day and It goes dead then I press the standby button and it displays the "need to charge" icon on the screen then disappears I charge it and it works fine the next day,I hope this helps-jade
Score 3
1 Comment:
can u try to help me
by
Add a comment
My iphone5c is blacked out but when I put it on the charger it ding what do I do
Score 2
1 Comment:
just hold the power and home button for five seconds, like your going to hard reset it. As long as you only hold it for five slow seconds it will work and it won't reset your phone. (this works on all iphones)
by
Add a comment
when i turn it on there is no screen but there is sound when goes off
Score 2
Add a comment
I have a Samsung galaxy phone with the same problem, It's blacked out but it makes sound. Is the only way to fix it to go to a repair place or can I do it on my own?
Score 1
1 Comment:
I have the same problem Just leave it for a day and then it should be working fine hope this helped
by
Add a comment
NY iPhone 4 is diving the same my screen was cracked u changed it now the phone won't come on but when I plug it up its making a double zig zig sound then a thump I recheck all my cables and the battery some thing happens
2 Comments:
try to connect it to the Comp. with USB and see will it recognize....if yes than is your board still good just check all the flex cabels
by
I changed the screen out again this morning now it lights up and talks but no apple logo its just blue I did the home and power button it just turn off and back to blue screen it go
by
Add a comment
my government phone is all blacked out when i put it on the charger and then if i try to power it on it makes noise
Add a comment
Mine has the same problem but I fixed it by leaving it for a day. It works perfectly fine now
Hope this helped you
Add a comment
My galaxy screen has been blacked out for about 3 days now and I still don’t know what’s the problem, at night I’ll leave it on the charger and till the morning try to power it back on again and again it makes noises when I power it back on but the logo will not appear on the screen and when touching the screen on my phone I can feel as if I’m pressing on the keyboard Someone please help.??
Add a comment
Add your answer
richonna will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 33
All Time: 14,025
