Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3295 Questions View all
Replaced Audio/power cable. Now none of them work.
My lock/power button stopped working so I ordered a new cable and button. Spent 3 hours painstakingly installing the new cable tonight, and now the lock/power, mute/ringer, and both volume buttons are all not working. They all have a physical "click" but no response. Clearly i did something wrong. Thoughts?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
Turns out I had the connector under the motherboard. Wasn't even connected! Working properly now! Thanks for your help.
Add a comment
If you make sure the new cable is good, you can check the connector between the cable and the mother board. May be you loosed the connectors carelessly.
Comments:
Add a comment
There are three points you need to check.
First, you need to check whether the cable is broken or not .
Second, if the cable is in good condition, you need to check the installed position is correct.
Third, if the position you installed is correct, you need to check the connector.
To know more about the cable or get a new cable, click here : http://bit.ly/1gbvVHI .
Hope will help you.
Add a comment
Add your answer
barstoolracer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 131
