Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
357 Questions View all
Do you need to buy a certain size hdd?
I just bought an a1237 and I need to replace the hard drive and before I go buying something I want to know if I have to buy a certain size for the laptop or if it's just a regular hdd?
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
Yes - if you don't get the correct HD it will not fit or work. It must have a ZIF connector not SATA and it must be 1.8" form factor, 5mm thick.
If this answer is acceptable please remember to return and mark it.
Score 1
Comments:
Thank you so much that helps a lot!
by
Add a comment
You need to know the size and type of hard disk in the System before you purchase. There are various forms of hard disk, although most System use the SATA now.
Comments:
In the Air's the "hard disk" is an SSD.
by
Add a comment
Add your answer
Quinten Gould will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 86
