The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
317 Questions View all
Comment installer un SSD pour démarrer dessus?
Mac Pro1.1 (2006) Système 0S:10.7.5
J'ai le kit à installer dans emplacement libre 2ème DVD.
Avant acheter le SSD, quel type connexion ? Sata 1,2 ou 3 ?
Schéma illustré montage, et branchement sur carte mère ?
Merci d'avance
Cordialement
English:
How to install an SSD in MacPro as startup
Mac Pro1.1 (2006) 0S System: 10.7.5
I have the kit to install in free slot 2nd DVD. Before buying the SSD, what type connection? SATA 1, 2 or 3?
Do you have instructions on how to mount and make connections on motherboard?
Add a comment
1 Answer
Chosen Solution
Here is a link to the guide for the machine and another for installing an optical drive. It is a PATA connector you will need to purchase a 7 Pin Serial ATA (SATA) 39" L-Shape (1 Meter) Connecting Cable Straight connector to Left Angle Connector Step #10 shows the logic board connection. Mac Pro models have two front-facing optical drive bays that support two standard dimension 5.25" 3 Gb/s Serial ATA devices (also called SATA 2.0 or SATA II).
To ensure full compatibility, it always is best to buy an optical drive and other upgrades from a trusted company with Mac knowledge for the most trouble-free experience.
If this answer is acceptable please remember to return and mark it.
Score 2
Add a comment
Add your answer
Alain will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 220
