I forget my pass code, how can I restate it
i forget my pass code, how can i restate it
ANJU GENIUS, Hard reset does not remove or change anything on your iPhone Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously.
Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart.
You may let go when you see the silver Apple logo.
You have completed a hard reset successfully.
Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen. This is normal." http://www.wikihow.com/Hard-Reset-an-iPh... A restore on the other hand will return the phone to its default settings and YOU WILL lose all information. You should only do that as a last resort and only do it on the computer that you normally sync with. That way it should restore the last backup. Check on here for directions on how to do that.
The only other thing would be to put your iPhone in DFU and restore, again YOU WILL LOSE all data since the last backup.
DFU Mode
Connect your iPhone to your computer
Turn your iPhone Off
Press and hold the power button for 3 Seconds
While continuing to hold the Power button, press the home button as well for 10 seconds
While holding down the home button, release the power button for another 10 seconds
iTunes should now detect the iPhone in recovery mode, press OK, and restore your iPhone. you may now release the buttons. If you have not reached this point, then you have not entered DFU Mode DFU Mode Good Luck and I hope this will help.
If you have forgotten the passcode on your iPhone, you can unlock you devices by restoring the device. Now follow guidance below to learn how to unlock iPhone by restoring with iTunes.
1. Connect your device to the same computer as you previously used to sync the device.
2. Run iTunes and then go to the “Summary” page. If iTunes fails to automatically sync your devices, do it manually after successful backup.
3. Click “Update” and iTunes will inform you whether there is a newer version of the iPhone software available.
4. Click “Restore iPhone” and follow the screen instructions to complete restoring.
5. Once restored, you can unlock your iphone and reset a new passcodes.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 189
