Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
423 Questions View all
Can I remove Display and keep Wifi?
So my Macbook Display is shot, and I was going to remove it, but I realized that either the Wifi Card or Antenna is built into the display.
my question, is it possible to remove the bulk of the display but retain the parts that contain the Wifi? For example, if I go ripping this thing apart, is it fairly obvious what needs to be retained to keep the Wifi? I don't mind if I have a random cable sticking out, or a small component attached to that cable, I just would prefer to loose the bulk of the display so I have easier access to the keyboard and trackpad (right now the frame/hinge area is busted so I pretty much need to keep the computer shut and use an extra keyboard and mouse.
Thanks for your help.
Add a comment
1 Answer
Chosen Solution
Yes - If you are careful you can keep the antenna(s).
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Add your answer
Stephen Snyder will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 108
