Can the computer itself make a HDD go bad?
Craigslist had an immaculate iBook G4 in my area for short money and I was able to score it for my kids to use. We use it to play music and movies and games. It had a 30G HDD but everything started to act up. Programs would just close during use, and then all I could get was the startup sound, a grey screen and the Apple with the spinning wheel.
So I decided to replace the HDD with one (250G) from my old iBook G4 that worked, however the logic board was failing me.
Everything was fine for the first 3 times I used the computer, then it started to act up in the same way it did when I had the 30G HDD in there. I reset the PRAM and the PMU already.
What else do I do?
Score 1
Comments:
+1 Great question! It's so helpful to know what steps to diagnose you've already tried.
by
Add a comment
1 Answer
Chosen Solution
Definitely not an HD issue then, you should run some diagnostics, such as the AHT, also take a look at the RAM.
Score 2
Comments:
Thanks, I R&R'd the RAM and it works again.
by
That's usually my second thing to check, 1) HD, 2) RAM
by
+ Ralph
by
Add a comment
Add your answer
040304 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 919
