Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1391 Questions View all
Is the hard drive caddy grounded?
When installing the hard drive, it worked fine without the caddy, but when I mounted the caddy and installed the drive, it acted as if the drive was shorted out because now it doesn't work. Is the possible? Or could it be another reason why the drive does 't work now. It will not be recognized by the laptop.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
You could have only partially connected the drive. Be certain you have it the correct side up.
If this answer is acceptable please remember to return and mark it.
Score 1
Comments:
ok! accepted.
by
answer accepted. It was not what i was looking for, but it sort of suggested that the drive just pick a bad time to outlive it's usefulness.
by
Add a comment
Add your answer
clc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 71
