How do I replace battery?
I would like to replace battery rather than get new phone. I have the Motorola Droid Razr Maxx. Is this possable?
Captain PJ Papnick, try this:"
1. Remove the memory card
2. Unscrew the two screws at the bottom of the phone
3. Use your fingers to gently lift the screen from the phone case. It will still be connected by two flexi-cables
4. Use a pry tool to gently remove the flexi-cable connectors from the board. The screen will now be free from the rest of your phone. Set it aside
5. Lift the adhesive cover off the battery connector on the bottom left of the board, then use the pry tool to remove the connector
6. Remove the 10 screws that connect the board to the back of the case
7. Use the pry tool to remove the adhesive cover affixed over the connector on the top left of the board, then to remove the connector
8. Use the pry tool to remove the three connector covers (they look like solid metal plates) and their corresponding connectors
9. Use the pry tool to gently pry the board up and off the back phone case. You will now see the battery
10. Use the pry tool to lift the battery from the battery compartment
11. Insert the replacement battery and follow these steps, in reverse order, to reassemble your phone" from here.
This video may help as well. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,116
