Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix.
174 Questions View all
What are the gold prongs along the right side of motherboard?
I'm hoping someone can provide a little detail about what I believe to be the grounding prongs on the Nexus 7 motherboard. There are 2 closely spaced at the top left, 2 with more space at the top right, 2 along the upper right side near where the batter plugs into the board, 1 in the middle of the right side, and 1 at the bottom of the right side. All locations are in respect to the device laying face down, charging port at bottom.
For the 2 near the battery input: If one is broken off, how will this affect the tablet? Will it prevent boot, or cause excess battery drain, etc.?
Thank you for any input.
Add a comment
1 Answer
Chosen Solution
Hey Brandon,
The top left prongs are for the GPS antenna, the top right prongs are for the NFC antenna and the prongs near the battery terminal are for the WI-FI antenna, if any of them are broken off it will most likely break the loop on the terminal pads which is needed to transmit the signal through one prong into the black antenna pads located inside the lid and back through the mobo circuit.
Im unsure of the purpose of U62 as it does not contact any terminal pads inside the lid but might have been placed there as is the large square hole in the chassis just above the battery for later modifications like adding a rear camera.
I hope this helps and if a prong is missing you can most likely find one similar in a laptop or scrap tablet and solder it on as a substitute.
Jeez i love to tinker
Thank you, Mike!
Add a comment
Add your answer
Brandon Martin will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 13
All Time: 535
