The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Questions View all
Question Closed
After YLOD repair, controller won't connect
Hi,
I successfully used the YLOD repair kit from ifixit to repair my overheated PS3. Everything seems to work great, except the PS3 controllers will not wirelessly connect to the system. I tried resetting the controllers and also tried pressing the PS3 button down for awhile after connecting with a USB cable with no luck. Any other advice?
Add a comment
Most Helpful Answer
Can your PS3 connect to WiFi?
It sounds like you forgot to hook up the bluetooth/ wifi cable
Score 1
Add a comment
I took it apart last weekend to check it out and the ribbon that connects the bluetooth/wifi cable popped right out...so you're right jzpittm. At least it was an easy fix. Thanks!
Score 1
Add a comment
Hi,
I ve got the same problem : try to reset the controller (Button at the rear)
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 637
