Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac Mini Server configuration.
177 Questions View all
Prepping SSD Swap, what is the maximum thickness of the drive?
I put the cart in front of the horse a little bit and I ordered the SSD before doing all of my research. I am seeing that all of the SSDs offered by iFixit for this machine are 7.0 mm and it appears the drive I ordered is a 10 mm drive. Am I going to run into space issues?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Ouch! Millimeters do matter here. Apple doesn't leave much free space.
Just the same you maybe OK here if you put the SSD in the top bay as the clearance is a little bit more. The HD's Apple uses are 9.5 mm in height so your SSD is 0.5 mm higher. Good Luck!
Score 1
Add a comment
Add your answer
Kyle Jurick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 141
