Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Questions View all
Question Closed
No Wifi Hardware installed, but bluetooth works
I've been having this problem for some time, and i recently found a ray of hope ( I think).
So my wifi card was giving me problems before after a fall from my MBP. Then, the display got dislodged from the upper casing, but my wifi was working just okay. Progressively, the wifi started getting spotty and i'd have to close and open the lid twice or thrice to get it started again, and finally one day - "No Wifi hardware installed".
Now, i managed to recently stick the display back in after getting rid of a ding on the side.
Weirdly, the bluetooth starts working now. Am i hoping for too much to expect my wifi to start working again?
Add a comment
1 Answer
Chosen Solution
I suspect you severed the WiFi & Bluetooth connection lines that go through the hinge area to the lid where the AirPort card is located. So when you move things about you are managing to reconnect things.
It's a bit of work to replace the cable harness IFIXIT guide to replace harness. So you might want to think about using an external USB WiFi and/or Bluetooth interface as being cheaper solution.
Or you could just replace the entire lid assembly IFIXIT Guide give the face the display keeps popping out and you have a few dents.
MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Assembly Image
Guide
MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Assembly Replacement
Difficulty:
Moderate
30 minutes - 1 hour
MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Image
Guide
MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement
Difficulty:
Very difficult
1 - 2 hours
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,891
