Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
88 Questions View all
Only Hynix RAM compatible with iMac 21" late 2013?
There're two Hynix RAMs in iMac 21 inch late 2013.
I tried to replace Adata, Kingston, Apotop, TEAM RAMs with Hynix RAMs, but is not working.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Standard RAM: 8 GB Maximum RAM: 16 GB*
RAM Type: PC3-12800 DDR3* Min. RAM Speed: 1600 MHz
Details: *By default, this system has 8 GB of 1600 MHz DDR3 SDRAM. Apple does not intend for one to upgrade the RAM in this system. However, as first reported by OWC, this system has two SO-DIMM slots (204-pin). Unfortunately, accessing these slots requires one to pry off the display that is glued to the case and remove the logic board.
Scroll down to get to the installation video on this link: http://everymac.com/systems/apple/imac/i...
Score 3
Add a comment
I have replaced the original ram with Corsair modules 2x8gb. No problems encountered.
Score 1
Add a comment
Has anyone tried 2x16Gb to get 32Gb working? Thanks!
Add a comment
Yes,
It is normal working with GoodRam 16GB 1600MHz
Add a comment
Add your answer
zeals75 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 2,086
