Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
iPhone acting strange then never turned on again.
Hi, i have an ihone 3gs bought on ebay. worked great for aproximately 4 months. never fell, no water has fallen over it. for no apparent reason the back light started flashing nonstop, so it sucked up the battery, when connected to power, phone worked just great. as soon as disconnected started flashing again. after a while it didnn't charge or wouldnt be recognized if connected to the computer. i turned it off to restart it and see if the problem would go away but it never turned back on. i thought it was the battery so I ordered a replacement one and changed it. phone turned on and worked perfectly withought the flashing light but when connected to the power source the screen blanked and turned off. i decided to leave it charging for a while to see if battery needed to be charged and the phone just got really really hot, after that it has never turned on again.
i am maybe thinking it may be the dock connector, or even the motherboard?? if so, are these replacement parts readily available?
PLEASE HELP!!!!!!!!!
Score -1
1 Comment
I noticed you never got an answer to this. Are you still having this problem?
by
Add a comment
1 Answer
Chosen Solution
If the phone has gotten really hot while charging, then there is something wrong with the battery or the charging circuit on the motherboard. If you've replaced the battery and had other strange problems (like the flashing), then it means that the motherboard is bad and you will need to replace it.
Score 1
1 Comment:
+ good advice
by
Add a comment
Add your answer
Tania will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,051
