Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
158 Questions View all
Mac Mini Dual Drive Kit - Upper or Lower bay?
Is the Mac Mini Dual Drive Kit for installing a drive in the upper or lower bay?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Please read through the installation guide, then ask your question: Installing Mac Mini Late 2012 Dual Hard Drive Kit
Score 1
Comments:
The kit's description does not say whether it's for the upper or lower bay. It simply says: "Mac Mini Dual Drive Kit". I read the install guide which also doesn't say. Could someone please clear this up? The kit is for the upper bay or the lower bay?
by
Add a comment
Most Helpful Answer
It's pretty well hidden, but they are assuming that the installed stock drive will be in the lower position. You can see this on step 37.
Score 2
Add a comment
I purchased a Mac Mini 2.3Ghz Intel i7 with 1TB drive from the Apple store last October. According to disk utility my Mac Mini has the standard fit Apple 1TB drive fitted to the UPPER bay, which seems to be unusual.
As I read the instructions it would seem that fitting a new drive to the lower bay - the one closest to the antenna plate - is actually simpler. However where do I get the mounting screws, shielding material and is the lower drive cable different in shape / length than the upper drive cable?
I found somewhere that there is two different cables, the Upper HD Flex Cable (076-1413) and the Lower HD Flex Cable (076-1412) so it seems they are different.
Add a comment
I don't believe they sell the parts here, but if they do, I would certainly recommend shopping here, the service I got when I had an issue of my own making was outstanding. OWC does sell them. http://eshop.macsales.com/item/OWC/DIYIM...
Add a comment
Add your answer
Tony Visconti will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 56
All Time: 5,981
