Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Question Closed
Dock Connector does not connect to battery
I ordered a new battery and a dock connector, and upon disassembling my phone I noticed that the connectors were not similar. The new one did not have the "#7" connector and the #4 connector is not correctly connecting to the hardware. Does this mean I was sent the incorrect connector, or how do I make it work? Or can you send the information that I need to fix it?
I have not had the time to put a lot of effort into it, so I have run past the return time, so I cannot return the one I have.
Add a comment
1 Answer
Chosen Solution
corey62931, the 3GS should have a cable number 7, not the 3G. Verify that you are having a 3G iPhone , not a 3Gs. If you do have a 3GS, then your new part is a 3G dock connector. Hope this helps, good luck.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 78
